Thinking about how I'm going to run my electric in my 1648. I'll be installing an aluminum floor with foam boards underneath. Was originally planning on running all my wires along each side of the gunwale in the "crease" that's about halfway up. I've been noticing that some guys run their wires under their floors and also have seen a few factory boats that have wires under the floor. It would certainly be a cleaner install under the floor, but I'm not sure how water would effect the wiring or even how the wiring would effect water getting back to the bilge. I'll be running the following:
-Starter wire for outboard
-Anchor light wire
-Fishfinder/transducer wire
-Interior lights
-Bilge pump wire
-Stereo wire
I'll for sure be running a stick steer cable and throttle cable along the gunwale "crease", so adding wire to that may get a bit crowded. But I'm sure there is enough room for everything. What say you guys??
-Anchor light wire
-Interior lights
-Bilge pump wire
-Stereo wire
