Spare spools
TinBoats Supporter
Shrewsbury, MA
For the people who actually get spare spools when they buy spinning reels.
Do you really actually use the spare spool? I always buy the spinning reel when it comes with a spare spool but I notice I never ever use it unless the one on the reel gets hacked up.
I rarely use it; I only use it when I put different line on it that I need (of course I only have 2 setups, 1 of them being a spinning). I used to put two different lb test monos, but now I only use one fluoro.
I do for my saltwater set ups. I keep a reserve spool for the inevitable loss of line. Usually the spare spool has the same test and type line as the one on the reel.
However, with that being said, I have never, ever swapped out a spool during the fishing day. I always just pick up another rod and reel that is ready to go.
I do carry an extra reel in my tackle bag when I am not on my boat as a backup.
I use the spare spool that came with my Sedona to keep spooled up with Power Pro Braid. I like to use it when i'm fishing the river because its alot more sensitive, then when I fish the lake, just switch em' back.
I almost always have it spooled just in case, but yep, barly used it. Speaking of spinning reels, last year I bought the Daiwa Exceler! Man what a great reel for the price! It takes a while before the line twist starts up. I bought another for this year too. Sweet reels, check em out.
I have heard nothing but good things about this reel. You can get it at dicks with the coupon for $55. I might bite. :D
I normally put a different # class line on it and use it depending on where I am fishing. That way I can use the same rod n' reel for smallies, trout, and largemouth on totally different bodies of water.
Fishin NJ said:
I spool them up but have never once used one of mine. Now once i start getting better reels this spring, I plan on spooling them up with different lines. This way i can test out a new type/brand of line and if i don't like it my trip is not shot, i just switch back. I also plan on buying a hard case to store the spare spools in.
I did buy one of these and its a nice little setup.
Spool Case
I generally don't use them, but when I do I will have the one I use most spooled with sufix braid, and the other filled with mono. The only reason I iver use mono is if I am fishing fast moving deep holes in the river and I need my line to sink faster than braid with a flouro leader.
I have a Daiwa Exceller too, for the price I cannot complain at all. I really can't complain without factoring in the price. I am unsure of my next spinning reel purchase due to the the new line of shimanos, but I may have to get another daiwa. They also came out with an exceller baitcaster, I handled it at a sports show and it feels pretty nice, and its pretty cheap too.
The only times i have used spare spools is when crappie fishin with ULs, The only reason i do that is because i normally only take one or two rods out. For whatever reason i dont work well with light line and, quite often seem to get it knoted all up.
For my lightest setup, I will actually change spools. When I'm fishing in a creek for bream, I'll use four or six pound test. I'll throw 1/32 ounce spinners and crappie jigs on that setup. When I'm fishing for bream in ponds or occasionally lakes, I'll swap out spools to one with 8 pound line on it. I try to throw where the fish are and that sometimes means pulling sticks back to the boat, so I need a heavier line. Also, I have just as good of a chance of hooking into a bass as a bream, so the heavier line lets me have that little bit of extra leverage on a bass.
I have a couple of spinning reels I switch spools on... mostly because I use those rods for both River and Lake fishing and need to change line size between the two. Other than that, I never use them.
Thanks for the responses.
Here is another question then...If your buying a reel, Would a determining factor be a free spare spool?
Would you rather a cheaper reel with an option to buy a spare spool if needed?
I never use spare spools, I found out the hard way the spare spool has more memory than the original spool, I carry a couple spinning rods, one for 6lb test and the other for 8 lb test, I carry a couple bait casters one with 10 lb test and one with 12 lb test. I'm set. If I plan on throwing another light line bait i rig another rod and the same with heavier line.
I rather put the money towards a better reel than buy one with a spare spool, This is just me saying what I would do, it works for me.
Generally higher end reels come with a spare identical spool. A lot of times if it is a cheaper reel that has an aluminum spool, they will give you a graphite spare spool. A spare spool kinda seems like a given to me, but it is hardly a selling point. I do, however, like having a spare spool around in case my drag gets worn out, I have a new drag ready to use.
No offense, but I really cannot see how a spare spool could make more memory than the original. Almost always the spare spool is identical, or at most a different material, but still identical. Did you have your spare spool spooled up and stored that way? If that was the case, having your line on a spool and not using will give you tons of memory. Was the line the same? Just wondering because I have never had any problems like that with a spare spool.
I think maybe if you spool it up and let it sit there for months and not use it, it could have more memory?
This happened the only time I decided to do the spare spool thing, dont remember how long it set without being used, it wasnt too long, since i change my line pretty frequent so instead of changing line i changed spool and what a mess, Dude no offence taken, I was stating fact, everyone has different experiences with fishing, now if you were to say i was bullsh#t thats a horse of another color, but I didnt take it that way.
