JMichael said:
DWD said:
Spider rigging is a blast..it can produce a limit real quick!! I live 7 miles from Grenada Lake, one of the top crappie lakes in the world. It can be a lot like work when all the poles go down at one time.
As in Grenada MS? Nice looking slabs in those pics.
For you guys that are already using spider rigs, do you mainly use your trolling motor or are you using drift anchors and letting the wind push you? Or maybe the weather/situation dictates what method you use.
yep, that would be MS. Never been but thinking/planning a trip there later this year.
For SR, use your TM, as you need to have a fairly slow (.3-.6mph) presentation most of the time , with 12-16' rods out front so the crappie see the lure/bait before the boat gets there. You need a gps unit to monitor your speed, and just the slightest speed up or down (like +/- .1mph) can make a difference in getting them to bite. got to find the right depth, right speed and then might have to add in which color do they want today as well. Most crappie fishing guys use the MK Terrova trolling motor with Ipilot, have high $$ HB or Low HDS units with SS/DS as speed control is very important in most styles with the exception of jigging or hovering over a brush pile. The Terrova w/IP has "spot lock" which is something like an electronic anchor based on gps location. The IP advertises the spot lock feature will keep the boat within a 15' radius, but that is somewhat inaccurate unless there is NO wind or current. The speed control feature allows mph adjustments in 0.1mph increments. Yes, I have a Terrova with IP, and it really is a great tool, you don't have to worry about the boat much while fishing your preferred method. the TM will control the boat for you, allowing you to do other things needed.
There are numerous ways to catch crappie, just like bass, there is SR, single poling (jigging), double poling, longlining/trolling, drifting, pulling or pushing crank baits, side pulling CB's as well. The different styles use the same basic equipment (TM, same rods, but can use different lures). Some fish only with minnows, some mix it up, some only artifical. I just saw a picture of guy double poling while he was longlining, so you can definately mix and match. All styles work year round, some better than others at times, some do one style and nothing but that one style.
