I have a 6 gal steel fuel tank that I got when I bought my 1960 starcraft. I have a couple of q's about the tank and hose.
I have a six gallon steel tank(Non presurized) that I am using with my 1960 18hp Johnson seahorse.
IS the bulb supposed to be rock hard , or somewhat hard after pumping a couple of times? Also,
My tank seems to be wet on the outside from fuel seeping out, even when it is sitting on the garage floor. Is this normal? I checked the gasket on the inside of the filler cap and it looks in poor shape. Can you replace these gaskets on these old tanks?
On my Johnson hose fitting, it has two holes and two small pins that are perpindicular from the larger holes. What do these do? When I attach my fuel hose to the gas tank there is a small gap where the two small pins insert into the connector. Is this normal? I think it is allowing air into the hose.
I have attached pics that I hope will help.
The motor worked ok 2 months ago, but yesterday it ran terrible. I'm wondering if it is the motor or the fuel sending system.
ski
ski
