You can use a hammer and screw driver to push the edges in to the middle then pull it out. You can make your own tool to install the new ones out of a large bolt and nylok nuts. You can get 2 piece plastic drains that work well.WhopperPlopper said:I also am looking to remove on that is on my transom as to replacement the transom it goes through it. I think they make a special too to put a new one in. Hope to hear from someone about it on here
lckstckn2smknbrls said:You can use a hammer and screw driver to push the edges in to the middle then pull it out. You can make your own tool to install the new ones out of a large bolt and nylok nuts. You can get 2 piece plastic drains that work well.WhopperPlopper said:I also am looking to remove on that is on my transom as to replacement the transom it goes through it. I think they make a special too to put a new one in. Hope to hear from someone about it on here
Hey, that's what we're here for, so ask away . I'm in the midst of a transom repair myself, so maybe you'll pick up a trick or 2 there.Just4fish said:Thank you for the responses this is my first job boat project .... Stay tune because I’m sure there’s going to be more rookie questions to come.
