I have a 70lb Minn Kota with the metal transom mount bracket from a 101lb Minn Kota. I hit a stump and ended up bending one of the threaded clamps. Can these be replaced?
Minn Kota's only suggest was to order a whole new bracket. How are these little cups attached to the end of the screw clamp? Looks like the end of the screw is peened out to hold them on.
There just a ball and socket....you can get them off by grabbing them with a pliers and turning them at a 90 degree angle. Getting new ones on is as simple as putting the new cup in place and running the clamp down.....reusing the cups is a trick in itself to get them to stay tight though.
