Value of 3 gal double line Johnson/Evinrude pressue tank
Tinny Fleet
Florida and New England
LOCATION
Melbourne Beach
Gents:
What would you put the as a value on a 3 gal double line Johnson/Evinrude pressue tank?
Came off a mid 50's Johnson.
A few datails:
1) just a little rust outside. Its been coated with some kind of off-white coating which has helped keep the rust at bay, but that will be stripped, sanded and repainted.
2) rust inside is minor
3) no hose
4) Cap is nice
I'm not going to take it apart and replace gaskets or anything.
Thanks!
Depending on the condition $25 Canadian to start
I have seen ads on Kijiji.ca where the sellers are asking over $100 Canadian but those were in like new condition
If the bottom of the tank is not rusted and the inside of the tank is not rusted. The "ears" the hose wraps around are not broken, no dents, visually nice, and it will pump I would start around 50-60. The tank is actually a 4 gallon and is more sought after than the larger tanks. Restored tanks that are rebuilt with new diaphragm, gaskets, seals, fuel line and o-rings will bring quite a bit more.
