Today I got to try out the fire extinguisher on my boat!!!! I was running on plane when I started to smell something funny. I immediately shut off the gas motor, and lifted the back deck. There was a small fire near the battery. I sprayed the area thoroughly with white powder, and then went to work to discover the problem. It seems it was the bilge pump wiring. The length of wire between the battery and the switch was all burnt up and smoking, and the fire was right where the wire hits the battery terminal.
The good news: the only wiring that will need to be replaced is the bilge pump wire, the others were not harmed. I hope the bilge pump is still good. I was able to continue fishing and ended up catching 20+ fish
The bad news: I have to replace that wire, need to add a fuse this time! And the rear of my boat needs a thorough cleaning.
I am guessing the problems was a short.... Any ideas?
