It is currently 22 Apr 2018, 08:18
eaglelodgemaine
 Page 1 of 2 [ 27 posts ]  Go to page 1, 2  Next
PostPosted: 28 Feb 2017, 01:35
Okay so I definitely did not need another project but my son and I were boatless last summer and I wasn't about to go through that agony again. He's now 4 and my daughter is now 2 so we needed to make sure that we got a big enough boat that the whole family could go out on. This one is a 1987 Alumacraft Lunker v16 and we found it on Craigslist for $1,000 with the original trailer (at least the vin numbers match) it also came with a Minn Kota Endura 55# 12v trolling motor. Ended up getting it for $800 which I didn't think was 2 bad as it doesn't appear to be in to bad a shape. Got her home and immediately removed the pressure treated floor and steel hardware that the previous owner had installed. Getting her ready for a leak test, if she checks out it will be game on! The plan is to keep a very open main floor space in the center and rear with 3 or so seats on pedestals and a raised deck up front where the original bench was located. Going to try to keep it simple as I want to get her ready to go before it gets really nice out. Stay tuned, this could get interesting...
File comment: Taking her home
File comment: Interior before I got my hands on her
File comment: Trash is gone, Almost ready to start building
PostPosted: 01 Mar 2017, 11:46
Great buy for $800. I would have jumped on that. Looking forward to seeing what you do with it.
Dudley
proud owner of a 1973 14' Alumacraft semi-v w/ 15hp Evinrude
:mrgreen:
PostPosted: 01 Mar 2017, 11:56
4 and 2 years old are the most fun times in life !!
I have many fond memories of being in old wood rowboats
and homemade skiffs as a kid, fishing with my parents and grandmother.
cherish those family boating moments !!!
they grow up FAST !!
I started taking my daughter out in boats at 6 months old and she still
has her love for the water and any type of watercraft. (she is now 44).
enjoy your new project ! looks like fun.
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
PostPosted: 01 Mar 2017, 12:29
Terrific catch. It looks like it had benches?
16 ft Lowe Jumbo V2 w/30 Mariner
14 ft Monark w/25 Merc XD sold
1994 Lowe 1605 w/50 Evinrude sold
14 ft Lone Star w/15hp Evinrude sold
PostPosted: 01 Mar 2017, 18:05
Thanks guys! Yes it had a bench up front but i believe that was it. The plan is to go with aluminum flooring if i can afford it, i'm waiting for material pricing right now. I have a battery, onboard charger, 2# pourable foam for under the deck on the way. I also ordered some solid rivets for filling holes where the previous owner had installed stuff to the transom and sides of the boat. I probably should weld the holes shut but to my knowledge it's only .063 and i don't want to risk doing more damage than good.
PostPosted: 03 Mar 2017, 14:55
Getting in some shop time with my friends equipment. Fabricating some small stringers and some hat channel that will fit over the existing supports and new stringers to create a flat floor in the center and rear part of the boat.
File comment: Slitter
File comment: Brake
PostPosted: 07 Mar 2017, 09:08
Okay so I decided while I have a bare hull I may as well strip and paint it. Stripping is under way. Any recommendations as far as paints go?
PostPosted: 07 Mar 2017, 10:18
Good score on the boat! Its nice to have friends with that kind of equipment Lol. Painting that hull should be simple, just scuff it up good, a 220 grit or higher should smooth it out and make sure you use a self etching primer first, then you can follow up with a good automotive primer to help fill in any scratch's. You can use any Acrylic enamel alkyd oil based paint, I like the magic brand from tractor supply. It shoots good, just use the proper hardener and activator. Good luck, looking forward to the progress.
PostPosted: 07 Mar 2017, 17:33
=D> =D> =D>
Love this setup!
1974 Lowe Jumbo V16
1986 Landau 1470F
1973 PolarKraft 1440 MV
1966 Johnson 20 HP
PostPosted: 16 Mar 2017, 17:15
Cool build! I've got the exact same boat, so I'll be following.
It's a pretty versatile little tiller...I've got a 40hp 4 stroke EFI Merc on the back of mine and it'll push along at 30 mph quite comfortably! I've fished it on everything from little rivers to bigger lakes like Lake of the Woods.
I attached the page from the '87 Alumacraft brochure so you could see the original layout.
PostPosted: 16 Mar 2017, 17:29
Wonder how the floor was supported with only one joist in the middle.
PostPosted: 30 Mar 2017, 20:31
Haven't made much progress yet, been busy with other things however I did do some shopping. Cabelas has a sale on swivel eaze products so I got 3 adjustable pedestals and 2 fixed ones. I also ordered a bunch of fasco steel flex. A few more things and some warmer weather and I'll be making progress.
PostPosted: 31 Mar 2017, 00:38
Nice boat. I can't wait to see what you do with it. A few tips for when you paint it, the self etching primer goes on real thin. Basically you should be able to barely see through it. Then a full primer job with regular primer which you then cover with paint. You can put the self etching on thick but it's just wasting the primer & money. I've also been told it's good to use primer from the same brand of paint you're going to use.
As far as the floor goes, if you don't want to add the extra aluminum you can take the blue or pink sheet foam & cut it up to fit the spaces on each side of your stringer. Then set your floor on that. The foam will provide plenty of support as long as the floor is resting right on it.
14ft Richline semi v
Sinner by birth...Saved by the Grace of GOD!!!
PostPosted: 31 Mar 2017, 00:48
It looks like someone hacked up the transom. Are you going to restore the transom to the factory height?
Online
PostPosted: 31 Mar 2017, 14:03
I used to be in the automotive refinishing business so I understand the entire painting, and even glassing processes, I am new to the Fasco Steel Flex product though so it should be exciting. The only real concern I have with the steel flex is its (Flex characteristics), is it flexible enough to hold up to the aluminum expansion and contraction of the aluminum or is it going to cause adhesion issues? I guess we will find out soon enough. As far as the transom goes it is cut down to 16 inches, I'm either going to clean it up and make it look nice at that height or raise it back up. The center stringer will be removed and 3 new stringers will be installed, Cross members similar to the ones directly on the bottom will slip right over the existing ones and span the new stringers giving me a nice flat area to rivet the aluminum sheeting to. I also have 2# pourable foam that will be poured under the floor completely filling all voids. I did want to ask though, should i leave a several inch gap along the center stringer to allow for drainage should any foam become waterlogged down the road?
Users browsing this forum: Moose6 and 60 guests
BoatCoversDirect
