12ftModder
I have been looking for a decent transom TM mount to make a rudder since i got my boat. I had asked friends to ask friends etc. to try and find me an old dead TM. so i could just cut off the motor and head and use the mounting bracket, shaft. Well I ended up finding just the mounting bracket part on craigslist, it had just posted. called to make the deal on price and to meet. came home with an almost new Minnkota bracket that the guy had taken off to use the TM on a bow mount.
So heres what i came up with, stuff I had at home.
Roughly 30" of 3/4" pvc conduit
2- 2"x 1/4" SS bolts,poly nuts
small piece left over plywood from boat moddin
and 2 very large zip strips to run thru the shaft holes because i only had the 3/4"pipe and the holes are for 1 1/8
And there it is for now. I plan on getting a piece of aluminum or a piece of glassed balsa to replace the ply and the correct diameter shaft, preferably keep it plastic. So if any of ya have an old dead MinnKota TM with the composite shaft, i'd be interested in about 24"-28" piece of it.
