1990 sears seaking
fishin_magician
Colorado springs
OK guys I'm new to this site as I just purchased my first boat. Man I am impressed with the comradery on this site you guys rock so quick to help and share ideas... Anyways here's the scoop I bought this boat the PO painted the outside with a shaker can and the inside with a brush.he used flex seal on all the seams... The trailer is newer.with an ez load tiltand new tires. The seats are swivel and are one season old. new 6 gal gas tank,primerbulb and gas lines.. The motor is a 1969 9 1/2hp evinrude 2stroke. Old minn kota trolling motor 28lb thrust.new deep cycle marine battery kept on a trickle charge. 3 life vests, ankor and paddles... All for $1600
I get the boat home and noticed when the PO painted it he replace the outside transom with regular plywood not sealed.. It was warped and splitting... I removed the outside transom board and also the inside as it was chipping away...I used x2 3/4 ply gorrila glued, scared and clamped.. I'm going to apply the fiberglass resin today and paint the inside if the boat.it was pink and white for his daughter. I was able to remove the stars with acetone.I think I'll leave it blue... I painted the trolling motor and plan to paint the ob cowl ... But my question is how and the hell do I take off these **** seats hahahah. Looks like if you turn it 90° you can access the 1/2 bolt that is going into the bench.... Is there a better way to do this or am i forced to scrape my knuckles removing the seat and mount or can I remove the seat then the swivel or does it all come off together... Thanks guys here are some pics
When I mount or un-mount a seat I use a ratcheting box end wrench and wear gloves.
Hey thanks man.. That sucks I knew that was going to be the answer
Here's an update... Sealed up the transom and cleaned the inside of the boat... I think I'm going to leave the seats and put trash bags over em and tape em down.. It took me 35 minutes to get one bolt out.... Smh
I got the electronic/bait holders put in. I'm still waiting on the cup holders,rod holders,docking cleats,rope,and inflatable bumpers
lckstckn2smknbrls said:
Sea King brand boats and motors were sold by Montgomery Wards
You are correct good sir.... I seen the label after I posted it... The registration says sears seaking... I just picked up this lure, compas and fish finder for $40 fish finder is like 10 years old .... I hooked it up to the battery seems to work. Works in demo mode but I guess I won't know till I'm on the water
I am all done just waiting on the cleacts and fenders.
Very nice set up for a fair price....then a little love later and it's your own;
A fine job!!
I like the side guide bunks on the trailer - might just hafta borrow that idea for mine as well!
HAPPY FISHIN'!
That paint job you did helped the boat wonders. Now I love it lol. Keep up the good build and enjoy slammin the bass in that bad boy.
