kensho1976
- Joined
- Sep 7, 2012
- Messages
- 48
- Reaction score
- 0
Hello all! I've been trolling the boards for a while, trying to learn how to do things without screwing anything up too bad. My father and I just purchased a bare bones 2012 Lowe A1667 from a local dealer and wanted to mod it for more storage and fishing ease. Unfortunately, the A1667 is labeled as a utility boat, and has three bench seats and a split bench in the stern. This doesn't allow for very good movement around the boat, especially for young children.
We threw in a side console, some slide rails for our folding seats, and a 2006 40 HP Mercury EFI motor.
Now that I'm getting a little more comfortable with the boat and have been out in the bay a few times, I have a better understanding of what needs to go where. I
've already cut out a small front casting platform out of 3/4" ply that will extend from the front bench to the bow. I just don't know how to secure it without putting holes all over the boat. I originally wanted to make it a temporary thing, in case I wasn't satisfied with the layout. After talking it over with my father, he suggested Liquid Nails/Gorilla Glue, and some SS screws into the bench seat. I'd still think it'd be wise to put something at the very front of the boat, just in case.
To add, I'm also thinking of cutting into the front and middle benches and putting some storage in. I'd replace the flotation foam that would be removed by adding a floor and putting the pool noodles or pourable foam under that. There's just so little storage on the boat, that it's really begging to be modified.
The other thing I'd like to do is cut into the rear half benches for the batteries or gas tank, and then cover that (with ventilation) with a back casting deck. The area between the back split bench and the first bench would hold coolers for catches, bait, and food.
I had a couple of questions before I put too much work into it, and damage the boat before it even runs out of warranty.
1) The foam inside the seats and benches is only in the case the boat floods, correct? It has absolutely nothing to do with the displacement or flotation of the boat when dry? Can I safely remove the foam as long as a put in more foam elsewhere?
2) The boat leans to the stern and starboard when sitting in the water empty. The engine must be a good 300 pounds, and the controls and cabling are on the starboard side. I'm concerned about adding any more weight to the back, and I'm actually thinking of moving the gas and maybe the batteries to the front. We've already wired everything, so moving the batteries are going to be a pain.
3) How can I secure that front casting platform? Do I need to anchor it at the front, or will the 3/4 ply stand up to 280 lbs only being secure through the bench?
Any suggestions/comments/criticisms would be greatly appreciated.
Thanks,
Brian
Thanks,
Brian
