driz
The boat has 50 merc that runs fine. Since I picked it up last year It behaved very badly only running trimmed nearly full down or bow rose excessively. Squirrellly handling porpoising ect. I tore it right down to the ribs expecting to find totally wet foam. Dry as a bone and it's a straight boat no bends or other damage showing. The motor appears to be mounted right fully down on the transom ect.
I am replacing the wood which what was on there was 5/8" in the middle ( huge piece) and 3/4 possibly 1" on the foredeck and peak portions. That seems severe overkill since the peak is supported completely and short span.with nothing up there but a trolling motor. Looking at these I have no real way of knowing if they are OEM or replaced and redone by prior owner. Once I had them out the cuts look a bit on the crude side around the braces which is what really got me to wondering. Its pretty obvious that some sort of weight and balance issue is creating this, there isn't anything else left. So tell me, What is the OEM plywood thickness of those front decks? I don't want to put this back together again to take it all apart.
