Just got the boat and finished replacing transom and refurbishing seat mounting. Moving on to the engine. The tilt/run/shallow water lever was broken off, and the tilt pin (or trim pin) was missing. The engine was pushing against the stern bracket tie-bar. The replacement parts are expensive and I'm having a hard time figuring out how to reinstall and set the reverse lock springs and linkage. The shop manual doesn't show a diagram, it shows a pic and it doesn't help much. The parts diagram on parts.net isn't helping much either. I was thinking of buying a used steering bracket for spare parts and a hands on look at how to assemble. Is there a good used parts source for these old Johnson engines?
