FishyItch
Last week I posted a question about a spinning throttle grip on my 1984 25HP Johnson. Well, I opened everything up and it turns out the outer half of the steering handle is broken. There is a circle the gear shaft passes through on this part, and this circle has broken off giving the gear shaft more wiggle room which is causing problems.
Anyway, I have two questions...
First of all, what websites do you guys use when buying parts for your outboards?
Secondly, is there any way to tell if a part will work despite it not being the right part number? For example, the part I need is 0322932 but this part is very hard to find. Is there a way to know if another similar part would work just as well?
Thanks in advance.
Thanks in advance.
