authentic
1 - I've got a 24v TM w/2 wires, all the plugs I see for 24v are 3 wire, what do I do w/that 3rd wire?
2 - I just need a decent plug that will be hidden most of the time. It doesn't need to be pretty, just do the job. I need both the boat side and TM side of the plug set up. Can someone give me a link to a decent setup for around $20?
3 - The batteries are going to be all the way in the back of the boat, since I've added so much weight in the front already, so I need to run cable all the way back. According to the marinco calculator I found online, I think only need 8GA wire to make that 15' run in a 24v system. That's the size coming off my motor and most plugs I've looked at, so that would make life simple. Do you guys believe 8ga is okay? If I go to something like 4ga, how would I go about connecting the bigger cable to the 8ga? I don't particularly want to keep adding busbars, if I can help it.
