How do you remove an old rod tip?
dyeguy1212
Top of the Food Chain
Darn rod tip lost an eyelet on my mojo rod, and got all bent to hell. Still have no idea how it happened, as its been sitting in my basement waiting for top water season.
Anywho, how to I get the old one off to install a new one? I don't want to rip it off with a pair of pliars and risk messing up the blank, but that's about the extent of my rod repair knowledge :lol:
Heat.
If there is some thread finish that crosses over from the wrap onto the tip top, you should remove that with a razor blade or X-Acto knife. That can be a hinderance to a quick removal.
Heat the tip top and with a pliers pull straight away with a slight twist. When warm enough, I should come off with very little effort.
St. Croix should be able to either send you a new one or tell you the replacement model.
Scrape any junk off the blank.
Some guys cut small slivers of tip top adhesive and drop them in the tube of the tip top. Heat the tip top and install.
I like 5 minute epoxy. I've had tip tops shift in the summer with the tip top adhesive, but never with epoxy.
As stated use 5min epoxy. i heat the tip just untill it slips off but make sure to cool the blank off as fast with a wet cloth. If you can't find a tip at the local shop to put on
the tube is in 64ths . I have tips from 5/64 to 10/64 in bright and black with rings size 6mm and 8mm.
Most tackle shops have a tip kit
Thanks guys! I might have to wing it on the sizing, as I need to get a new tip today, and St. Croix isn't open... is there a general catch all size? I'll be using 50 pound braid, so I was figuring an 8mm.
Take the rod and old tip with you to the shop - the size referrers top the diameter of the rod where you glue the tip - your line weight has nothing to do with it (and what the heck are you using 50lb line for - Tuna?)
Oh I thought the dia was the size of the eyelet (that the line goes through).
And the 50 lb braid is for my frog.. its the frog and slop rod.
Trust me, I've needed ever bit of it before :lol:
Tip tops are sized by the ring size and then the tube size. Tube sizes are in 64ths of an inch.
Example: BFAT6/6.5 = ring size 6mm, tube size 6.5/64ths.
I do not doubt that epoxy holds great.....but how do you remove the epoxied tip when you need to repair it?
I DO NOT use epoxy rather a super "rubber cement" type adhesive, usually Household or Marine Goop
This stuff hold fine and if you need to remove teh tip, you just heat and gently pull as is explained above
https://www.eclecticproducts.com/ag_adhesives.htm
Heat. They still come off with heat. More heat than the glue sticks so you never have to worry about your tip moving on a hot day.
