hipster dufus
recvd my noco 2 bank charger today. installed in bilge area.. routed wires. had to put on floor of bilge. mounted on waterproofed plywood. too heavy to hang on wall of bilge with screw, no way to bolt thru.i was using a shumacher smart charger to charge 1 batt at a time. the tm deep cycle would go green,100%, in a timely manner. the starting battery always showed charging, red led,.so when i hooked up and plugged in the noco 2 bank, the tm deep cycle went green after a short time. the starting battery is still showing that it is charging. is this normal? will it go green eventually?both batteies are 1 month old. tm is a grp 29, starting is a grpn24. 2 chargers same issue. thanks for your replies.
