heavy-chevy
new to the forum here, just got a 14' boat for a few weeks ago for $30 from a friend and have already fully decked, and carpeted it, added a console with steering and throttle and got a 25 hp johnson for $50, runs like a champ now. it all totals out to around $300 after parts/hardware and i split the cost/work with my brother so it ended up a pretty sweet deal. anyways, the problem is the motor is a long shaft. i took it out for a test run today and it refuses to get on a full plain. it just plows along at like 15mph with half the leg of the motor dragging and it just bogs down. the non tiller model doesnt have an additional piece between the mid section and lower unit, so short shaft is 20" and i cant convert to a 15" shaft that way, so i want to build the transom up and was wondering if anyone has done it, or if its common at all. if any one has some pictures if they have done it that would be great. will i need some braces to the floor or will just an extension piece with plywood in between that runs down the transom on both sides be strong enough. i need about 5". i have some 1/4" (edit: i meant to say 1/8") aluminum and some plywood already.
thanks
thanks
