BassBlaster
I purchased a single bank on board charger for my boat but am a little confused based on a few other comments Ive read. Ive seen mention that everything should be disconnected from the battery before charging but the idea behind an on board is that all you have to do is plug it in. So, should there be some sort of disconnect switch between the battery and the buss bar for use when charging? If so, how large a switch should it be, where would I get it and how do I wire it up? I would assume this would only be wired on the positive side?
Another quick question about on board chargers in general. My charger is the BPS model that Pro Mariner makes. Its a 3 stage smart charger with the third stage being a maintenance mode. Does this mean the boat should be plugged in at all times when its not being used?
