The only 5/8 Exterior grade plywood locally available is pressure treated heavy stuff. I'm thinking of using Interior grade, coating with two good coats of Acrylic Latex Enamel and then adding the marine grade carpeting and in so doing, will be coating the edges with Liquid Nails as well. The boat will be garage kept once modified. The edges will be rounded before painting and any voids will be filled as well before paint is applied. I'd appreciate hearing your experinces that may apply to the above. Thanks, and Good Fishing, Mac
