I have a transom dilemma. As you can see in the pictures there is a reinforced transom cap rated for 65HP. However due to the shape and space I had to cut the old wood out since there is no room to tilt or twist it to get it out. And unlike a normal Jon boat where you can remove the top cap to get to it this one is welded on three sides. If you look closely the front section ledge on each side has a riveted bottom but even if I remove them and bend it upwards I do not think I can get a new transom in. The corrosion under the wood was bad and it is through the aluminum in three spots the largest a 1 inch hole (see in pic next to ledge drain hole). The PO used treated wood and steel bolts for additional reinforcement when the wood started to rot and it ended up making it worse.
So I need suggestions? Grind the weld off the top cap and put wood in? But how to I re-weld with wood in there? Make transom in three pieces and two layers laminating in place held with screws till glue cures?
Also the corroded holes; do I patch weld the holes or replace entire rear of boat? I am paying someone to do that part. I am average at welding steel but I do not want to practice aluminum on my boat.
Any suggestions and insight is appreciated.
