norcal17western
- Joined
- May 12, 2016
- Messages
- 5
- Reaction score
- 0
Greetings all,
Just found this forum and realized that everyone on here is doing *exactly* what I am doing to my old Western 17.
I bought the boat about a year ago with plywood floors that had rotted through, a rock solid 30HP Tohatsu 2stroker, and a 5 year old trailer. Fast forward, blood has been spilled on the decks, a new 50hp evinrude has been rehabbed, and I thought quite a bit about the layout and what I want to do with her.
A few things on the list:
1) Move foam from the side bunks to underneath the floor (or not at all)
2) Move the gas tank to a topside closer to the bow and extend the fishing platform over it
3) Install two scotty down riggers
4) Install perko switch and dual batteries under the console (weight distribution)
5) Re-inforce transom to accomodate 50hp 4 stroker (weights about 250lbs)--boat was originally rated for 65
6) Install 1/8" aluminum sheet on narrow spans and 3/16" aluminum on wide spans down the middle
7) Install diamond plate lockers on the back bunks
8) Rehab her for another 25 years of service!
9) Install a few swivl'eze mounts around the boat for mobility
Will provide a few progress pictures as we move along and thank you for the questions I am sure will come!
Outside view:
After cleaning out 25 years of gunk off the bottom (pressure washer and shop vacuum)
Plywood layout on aluminum scraps I bought, borrowed and had laying around:
My best friend for this project:
First weld of many (give myself a solid C), note I have spare material on both sides so the finished product will look good, just wanted to lay a bead today!
Thank you all for the inspiration..
Outside view:
