who knows 2line pressure tank systems..
Sinkingfast
Never liked the "modern" suck fuel from a tank setups but made due. I am at a point in my boat project where I might go to a two line pressure tank setup with a permanent 12 gal tank. But i have some questions before deciding.
Where is the pressure safety release vent to, if there is one.
If there is one, what is it set at.
I must use a check at the pulse port and should be low mass as to move at 84hz? Not sure...
What is normal operating pressure.
If I tilt up the motor under pressure will the carb float drop allowing fuel to spill.
Yes I will do some research but this is part of it.
Just got 4 inches snow...not happy
Oh, and where to put primer bulb in fuel line..thanx
I'm feeling better now, snow is almost melted away...
A 10 minute look into a pressure system setup has melted away my enthusiasm also...
Life is okay now. Back to my spark plug inductive battery charging system...
Good to see ya back Pappy...
pre 93' 9.9/15omc
I did not realize that the two line system pumped "air" from both cylinders it seems. Since the motor is all back together I guess opening up a second hole in the case is outta the question..although I could wing it. One port probably won't be enough to charge the tank well enough.
I need to make a blow tube with a check valve so I can blow into the tank when the motor slows...yea..use a bike pump.. :lol:
Again, glad your back..
