14/36 Mod idea
sambrent18
Kingsport, TN
I'm thinking about cutting out the 2 bench seats in my 14/36 jet jon and putting down foam between the ribs and aluminum on top with carpet over that. I want to get all the weight to the front as much as possible. I was wondering if i can put the fuel tank up front and build a small deck over it with my batteries. Will the motor pull the fuel from that far or does it need to be closer.
Thanks
I would think you should be fine.. SeaArk and a few other companies have had forward tanks for better weight distribution for a while now..
Well it's a 30 powerhead so i'm loosin some ya know. It pushes real good when it runs right still tweakin it a little. That's kinda my deal is when i'm by myself it rides nose high more than i like which i understand cause all the weight in the back. That's why i'm wanting to move alot of weight forward. My batteries are under the front bench seat but I would like to cut out both benches and extend the front just enough to cover gas tank and batteries.
