Sean
First off, great site! I am glad I found it and hopefully will be able to contribute.
I just picked up my first aluminum hull, a 16ft Lowe Sea Nymph V with a 1998 Evinrude tiller engine with out electric start. I am pumped on the simplicity of the engnie compared to my last engine, a 225 EFI, but can't figure out some of the obvious...
1st: How do you shut the engine down? I'm just pulling the safty/kill switch now or backing all the way down on the throttle and the engine boggs down..
2nd: Whats the "mini" tiller at that is ath the end of the tiller arm that goes into it? Is it to adjust RPM's/Rev? It screws in and out and havent playrd with it much.
3rd: Before water comes out the tell tale, is there a time frame until the thermostate opens? I have let it run a few minutes with out any water coming out, but seems some exhaust or air preasure is puming out? Yes, its the tell tale not the exhaust...
$th, and final for now... Will this engine have issues putting a 16ft semiV on plane? I see some guys on here with upto 40hp so I am sceptical...
Thanks in advance for your help!!!
