58 gale 5hp
Well worth the effort and very nice running engine as well.
Make sure you touch all the bases before running (Water pump, gearcase seals if needed, ignition and carb)
A 20:1 mixture is recommended for that engine. Do not run it on less than 24:1 as it is a plain bearing engine.
Was not expecting this, of course I have never disassembled a outboard before. When I removed what I thought were the heads I was expecting to see the top of pistons. Just a dome with a hole for spark plugs. I am guessing that on e I split the crankcase the pistons come out and I just have the cylinder walls with no access to the top of the cylinder?
Where are you looking for pistons?
And yes, they are beyond a concern. Less than the recommended oil ratio or...a water pump failure occurred and the owner kept running.
You may find what you are looking for at www.aomci.org.
There is a free "webvertize" section there to find your pistons as well as a free "ask a member" section. They are the Antique Outboard crowd.
Am betting you will find what you need there.
