Alumacraft Floor
[email protected]
Oskaloosa, Iowa
Hello, I have a 2005 Alumacraft 165 Magnum Tiller. It has carpet on the floor that is still in good shape, just dirty.
I am thinking about replacing the floor carpet only with a vinyl flooring. I am not sure it would be worth it if I have to remove all compartments that are on the floor...live well, rod locker, control center. And I really don't what to remove the front deck.
I am thinking about how I could just cut the floor carpet out/up on the floor section and gluing the vinyl to original plywood. Butting the vinyl up to the edge and maybe putting a trim strip of some type along the edge to cover up and hold down the vinyl.
Or getting some 3/8 marine plywood and gluing the vinyl to it and putting it on top of the plywood floor after I remove the carpet .
Here is a photo of a boat just like mine, not mine , but just like mine
Any suggestions or helpful tips ?
Should I dive into this project or just leave the carpet ?
In a way I think I might be opening a can of worms .
Thanks for your time,
Mike
You will open a can of worms! Most likely the carpet is severely glued down.
Pressure wash the carpet and live with it, or do it right and pull all the plywood out.
Sent from my SM-G960W using Tapatalk
