Deck question
One important thing about trested wood once you cut it, its no longer treated.
You have to treat the cut section yourself.
But if your going to use it as a frame then it should be ok, just treat the cuts, although I'd sill treat the lot with Creosote myself.
For me its a weight issue. Treated wood is heavy. You need the least weight possible.
I just went with 1/8 aluminum sheet.
For the pedestal -- How far back as you want it. Its more of a support verse comfort level. Pedestal is a lever and magnifies stress.
