Since this is my first time working on a motor, figured it would be good to have the manual to guide me through the rebuild. I found a manual on ebay for $15, just figured I'd check on here first before I buy.
Thanks for the info, That gives me an idea of what I should be cleaning up. Only problem I seem to have now is I can't get the Flywheel off to to clean up the parts underneath. Beside the nut on top of the flywheel, is there anything else holding it on? I even used a rubber mallot to try and loosen it. For now I sprayed the area of the nut with PB Blaster and let it sit overnight in an attempt to loosen it up. I'll have some pictures to post later.
Also, where did you order replacement parts? I see sears has some, but figured there are probably better sources for parts.
