If you have priced marine grade, you wouldn't look at that as an option. Having made that mistake once, I would only use it if making a plywood hull. Go to Lowes or Home Depot, and look at what they have. They should have a sheathing, which has a reasonably good side, and a bad side. But, every now and then, a pallet of this stuff will come from a good tree, and will have 2 good sides naturally, not because they fixed it with footballs. The next grade has all the voids in the 2 outer plys filled with footballs. It also has both sides lightly sanded. If the sheathing isn't from a good batch (which it usually isn't) this is what you want.
