Congrats on your first Jig Fish! The first one is the hardest one =D>
Seeing how you've gotten braid and mono responses....I'll go with Flouro :mrgreen: , and here is why I like flouro. As you may know, in the winter when the matabolism of the bass slows down, they aren't going to chase down their prey like they would during other times of the year. That said, it's fairly traditional to think that in the winter, you have to work your baits slow. In most of the lakes I fish this year, I'm trying to find the clearest water I can, even though...muddy/stained water will warm faster when the sun is out. I've had much better success in the winter fishing in the clearest water I can find and I feel it's simply becuase...the bass is much more reliant on seeing his food this time of year, rather than spending any energy searching out what he hears but can't see.
So, I'm looking for clear water and I'm working a bait slow. Both of those factors make flouro the right choice for me, as I want to present the bait in the most natural way possible. A slow moving cold-water crawfish just inching along the bottom. Ever so often I will give the rod a light twitch, but for the most part, it's simply dragging the jig along the bottom at a snails pace. While doing this, the bass can get a pretty good look at the bait without having to move too far, and I don't want the line to be part of what the fish is interpreting. You also found that in cold water, wood cover will heat up too and could very well be a reason why that bass was using the spot. :wink:
The more I use braid, the more I have found that it really only helps me in specific situations, and neither have to do with sensitivity. I like braid for throwing topwater frogs over grass and pitching in or around heavy grass. The common denominator is heavy grass, and I am usually using 40 or 60# braid to cut through the grass and "horse" a fish out before he can bury himself in the grass.
What I don't like about braid....The exact issue you had. You never felt the strike. Braid is sensitive so long as you stay in direct contact with the bait. If you allow ANY slack in the line.....you'll never feel the strike. And for me, dropping the rod tip just a couple inches creates that situation. Mono on the other hand...is much more forgiving in this respect, and flouro is inbetween the two. For me, flouro wins for the reasons I explained above. Line watching is part of any slow presentation, but fishing in the wind or low light will make line watching tough. I want to feel every bite, so keeping tension on the line at all times is a must for me. Otherwise, you're left thinking.....I wonder how many bass bit and then blew out my jig :lol:
Black and blue is tried and true! Good job on the video commentary too
