Lund 16 Foot V Bottom Boat
IDFisher
I am new to this post but have been researching others modifications on this site. I have started my own conversion with the help of many of the posters on this site. Thank you to all of the previous posters for your ideas.
Here are some more pictures after removing floor board. When I pulled the floor board, I found a lot of weeds and an old lock underneath the floor. Some of the foam was wet and I removed the wet areas an I am going to replace it with expanding foam. I also removed the foam along the seam where I found leaks and rivets leaking. I am going to seal the seam and reshoot the rivets that are loose. I am an aircraft mechanic so I have a rivet gun and bucking bars to do the job. The sealant is also aircraft quality so I am hoping it will do the job. I am replacing all of the floorboards and building a fishing deck with storage on the front from the seat forward. I am also extending the storage on both sides of the middle deck area and putting a seat post in the middle for a third fisherman. I will post more pictures when they come available. It has been cold here in ID, so I have to move the boat in and out of garage to work on it. I will get some more done this weekend.
jasper60103 said:
Nice rig. I like the simple flat floor and keeping it light weight.
Thanks, It is a nice layout. I just need more storage space and have to take a little bit of the sides to make more storage.
