trolling motor shorting out
thereverend
Salt Lake City, Utah
I looked through the search to see if there were similar problems to mine but didn't find anything so I apologize if this is old news.
I was out a the lake about 2 weeks ago and I was only able to use my trolling motor due to another problem with the gas motor... to make a long story short, about 20 feet from the dock the handle seemed to start shorting out. If I twist the handle to just the right spot, it will kick on for a moment but all the other positions that I turn the handle to, I get nothing.
I'm not to strong with electrical stuff but I'm a pretty mechanical person... if you all have any suggestions on what I should look at before I pay someone else (or bite the bullet and save for a foot controlled unit), I would appreciate it!
This is the newer version of the motor I have... https://www.amazon.com/gp/product/B..._m=ATVPDKIKX0DER&pf_rd_r=0EPNA1ZTGKH5PRFC5PAK
Thank you,
andrew
i've been having a similar problem with my minn 30. every once in a while it stops working one day,and no problem the next.its not from overheating,and no fishing line is wrapped around the shaft.its 6 years old and gets a lot of use so maybe its just altogether worn out.maybe its time for a new one.
you have a rotary switch in your handle that controls the speed forward n backwards, they wear out or short out.. Replace it, its easy and not to spendy from what i remember..
I would verify this is the correct part for your specific model, but it will be similar.
https://www.trollingmotorparts.com/default.aspx/act/Catalog.aspx/catalogid/8583/Subcategory/Switches/category/Minnkota/browse//MenuGroup/Home/desc/Minnkota+5+Speed+forward%2f3+reverse+Switch.htm
https://www.fish307.com/minnkotatrollingmotorreplacementparts.aspx
has 94 and up diagrams
https://www.trollingmotorparts.com/%28S%2851s101453mpx43efda4uq5yk%29%29/default.aspx?MenuItemID=186&MenuGroup=home&&AspxAutoDetectCookieSupport=1
has 91-97 diagrams
+1 i have the same probllem with my minn kota 40 lber
