BassBlaster
Okay, next step in the boat build is wiring. Ive wired up multiple car stero jobs and trailers but never a full on new build project. So.....I need some help. First off, I purchased this switch panel.....
https://www.gandermountain.com/modperl/product/details.cgi?i=71709&pdesc=LED_Switch_Panel_6_Gang_Switch_Panel_6_1/2_x_4_1/2&str=switch+panel&merchID=4005
It has 6 switches. They will be used for, nav light, anchor light, courtesy lights, bildge, cigarette lighter plug and the last one isnt spoken for yet. I may wire up some lights in the storage compartment with that one as I'll have extras. I have 14, 10" 24 led strips coming and I dont need that many to light the deck up.
What else do I need? I know I need a circuit breaker for my trolling motor, I will use 8 guage wire for that because thats what came on my TM plug. What size breaker? I also read somewhere that there should be a main breaker between the battery and the switch panel. Is this necissary? If so, what size breaker? Also Ive seen where some are using buss bars. Makes since for the ground side but what about the positive side? Cant I run a single wire to the switch panel and then everything get its power from it or is that a bad idea? If someone has a simple basic diagram they can post, that would be great. I plan to use all waterproof connectors and may even shrink tube on top of them. What size wire is reccomended for the lights and bilge?
Is tinned wire really necissary? I read somewhere that it wasnt but if it is then I definately wanna get it. Ive done everything else right so I dont wanna slack on the wiring job.
Lots of questions, I know. Thanks ahead of time for the help!!
