MrGiggles
I recently brought home a Tracker Tournament V17.
It has a 60hp Merc 2 stroke with an unregulated charging system. It makes ~14 volts at idle and 15 at cruise. Common from what I have read.
I'm going to run two batteries, the main starting battery which will run the lights, motor, and sonar. The second is only for the trolling motor and bow mounted sonar.
I'm thinking about running an Isolator relay to connect both batteries when the outboard is running, to help keep the charging system loaded (to minimize electrolyte loss on the starting battery), and give a little bit of a boost to the TM battery, even if it's not much.
Is this a good idea? If so, what is a good relay to use?
