mmf
OK, getting some of the smaller things done but necessary. We had a big storm roll in last night and everything is wet this morning. First off, got the Teleflex steering all installed and the helm adapter fabricated, drilled and installed. This helm does not have offset bracket that the original had so the steering wheel is more horizontal than the other one.........
The rack protruding below, will be hidden when I get the console switch plate made
Close up of the adapter plate........
This is where the steering cable originally went in except it went in the tube with the wiring...
This is the 2" PVC pipe I added for steering cable to go thru as it goes thru storage compartment.....
The fuel compartment where the steering cable tube terminates supported by the pipe clamp.........
This is where the cable protrudes thru the splash well. Hole edge is covered with stainless/rubber edging.................
Addition of stern/bow light socket...........
Troll motor mount where it will be located, I chose this location so neither the head or the prop will be in harms way................
Removed one side decals and numbers, still have to get of the glue.............
Laying out position of front switch panel I am making...........
Assembly of front switch panel
Adding support/water deflector to underside, this will strengthen the panel in case it gets stepped on and deflect any water away from the switches when it is mounted...........
All riveted up ready to install, will drill switches, light, troll motor receptacle later..........
This is the installed position, I drilled the metal and tapped for 10-32 stainless button head screws......
Next to last is the console switch plate then installing of rod tubes. Getting to the end is in sight!!!
![TRACKER%252520UPDATES%252520082111%252520001.jpg](https://proxy.imagearchive.com/b76/b7642efd548afe5a6284d0661f5b59eb.jpg)
![TRACKER%252520UPDATES%252520082111%252520002.jpg](https://proxy.imagearchive.com/f7c/f7c4a79d2360b6f87ae7f32aa70d969a.jpg)
![TRACKER%252520UPDATES%252520082111%252520003.jpg](https://proxy.imagearchive.com/e2c/e2cd9482c96ca8e3ba09e6d151b8e2c4.jpg)
![TRACKER%252520UPDATES%252520082111%252520007.jpg](https://proxy.imagearchive.com/c43/c435a9866066bfa1cc8ae73da7238fe5.jpg)
![TRACKER%252520UPDATES%252520082111%252520006.jpg](https://proxy.imagearchive.com/e80/e80054d9ec66ca5f5f36e2f95560339d.jpg)
![TRACKER%252520UPDATES%252520082111%252520009.jpg](https://proxy.imagearchive.com/b9c/b9ccd47c44c24f8b20c3c5abc106e18b.jpg)
![TRACKER%252520UPDATES%252520082111%252520008.jpg](https://proxy.imagearchive.com/53c/53ca1b030568fcaf1b9c31e00cb344c3.jpg)
![TRACKER%252520UPDATES%252520082111%252520010.jpg](https://proxy.imagearchive.com/ba6/ba6f4cc224b6d2f6d247187a64ef91b7.jpg)
![TRACKER%252520UPDATES%252520082111%252520012.jpg](https://proxy.imagearchive.com/7f9/7f9ead890cc09c22531c002c17557d4a.jpg)
![TRACKER%252520UPDATES%252520082111%252520013.jpg](https://proxy.imagearchive.com/576/576c945bab9f65fb1e0eca57c299fb79.jpg)
![TRACKER%252520UPDATES%252520082111%252520014.jpg](https://proxy.imagearchive.com/949/949e079c7809c368cf48e4413d934677.jpg)
![TRACKER%252520UPDATES%252520082111%252520015.jpg](https://proxy.imagearchive.com/1ba/1baafe69d52f111c4ce720d094211008.jpg)
![TRACKER%252520UPDATES%252520082111%252520004.jpg](https://proxy.imagearchive.com/6f2/6f28611b59e647da4d3bc4a554030899.jpg)
![TRACKER%252520UPDATES%252520082111%252520005.jpg](https://proxy.imagearchive.com/2a0/2a0f28caec92a253188ac84ec5a5b097.jpg)
![TRACKER%252520UPDATES%252520082111%252520016.jpg](https://proxy.imagearchive.com/db2/db29b97bc23f3db2511ee07d7e3bf5f8.jpg)
![TRACKER%252520UPDATES%252520082111%252520017.jpg](https://proxy.imagearchive.com/ced/ced3974f74720eb6df145346308f369f.jpg)
![TRACKER%252520UPDATES%252520082111%252520018.jpg](https://proxy.imagearchive.com/9b8/9b86322cb050ddfe3aea49cb1f0641ee.jpg)
![TRACKER%252520UPDATES%252520082111%252520019.jpg](https://proxy.imagearchive.com/432/432479d6ed5b5c958b28a011da4581a0.jpg)
![TRACKER%252520UPDATES%252520082111%252520020.jpg](https://proxy.imagearchive.com/923/92363872deb197e42f860bdb56fc3f7a.jpg)
![TRACKER%252520UPDATES%252520082111%252520021.jpg](https://proxy.imagearchive.com/df7/df7f4be8b340876686f561f80c8a48be.jpg)
![TRACKER%252520UPDATES%252520082111%252520022.jpg](https://proxy.imagearchive.com/39f/39f219f4e328f33aba0987efef9923fe.jpg)
![TRACKER%252520UPDATES%252520082111%252520023.jpg](https://proxy.imagearchive.com/32f/32f1b4da5e8c2e1aa21357d0725187af.jpg)
