My beautiful boat has transom rot
1960 yellowboat
Homosassa Florida
3 Years ago, I replaced the rotten plywood transom boards with 3/4 inch pine board as I thought it wouldn't rot. Today I went out to run the 55 Evinrude and get ready to take the boat out. That's when I discovered that the board inside had rotted to the point it was crumbling. I varnished and painted it over the years so I thought it would last. After reading other transom posts on here, I know not to use plywood but are pine boards no good too? Would oak be better? The funny thing is that the wood on the outside that the O/B rests on is still hard. The wood transom has a metal plate over the top that mates with the outboard securing plate over the wood. Did I trap the moisture in?
By all means use plywood, but NOT pressure-treated plywood!
Look up the 16 foot Sea Nymph in my signature (#3), as it has a new transom, 2 pieces of plywood epoxied. It is still going strong with zero rot and used in salt water, attached with stainless steel hardware (properly insulated from the tin).
Thats a real nice job but my boat has reinforcement piece going from the hull to the transom. So i am limited to a piece maximum of 7 1/2 inches deep. still hoping to use one piece of 3/4 inch cedar
There is another active thread here on this same subject.
I would think the pine wood available these days has little to no rot resistance.
You can cut plywood to any size you want. I can understand why you might not want to waste an entire sheet of plywood for a 7.5" piece. Every home improvement store I've been to has a bin of cut down sheets for sale. Check to see if they have B-CX in the thickness you want.
I personally would opt for exterior plywood, but if for whatever reason you want to use solid wood, I would pick white oak over cedar. Whatever you use, seal the heck out of it.
