Trolling motor quick disconnect
Fishfreek
TinBoats Supporter
East Central Florida
Getting ready to install my transom mount trolling motor on a custom made bow mount. I am looking for some type of quick disconnect that I can wire the trolling motor to so that it's easy to remove. I'm not installing a traditional TM plug into the deck because of the saltwater around here. I'll never be able to keep it completely dry.
Any ideas and pics would be a great help..
I went to Amazon and checked forklift connectors as they connect the battery negative and positive leads in a neat little connector block. You need one connector for the battery and another connector for the trolling motor. The connectors should be "dead front" which means they won't be shorted if the come in contact with a conductive surface; a metal boat, tool box etc. In scrolling down the page on Amazon, I found power winch connectors.
6-8 Gauge Battery Quick Connect Plug Kit Winch Trailer 50 amps - type this in search and check it out, on sale for $15.49
May be ideal for your application.
My local WM has MK QD set ups for <$20, heavy gauge wire designed for use with TM's, one end on the battery terminals, other on the TM power wires, takes 5 seconds to make the connection, used 'em for yrs.
https://www.westmarine.com/buy/minn-kota--trolling-motor-quick-connect--1999804?cm_mmc=PS-_-Google-_-Shopping_PLAs-_-1999804&adpos=1o4&creative=54602133964&device=c&matchtype=&network=g&gclid=CM3qota97cwCFQ8kgQodZpQJiA
https://www.amazon.com/Battery-Tender-027-0004-BK-Trolling-Connector/dp/B002UCLJG0/ref=sr_1_2?ie=UTF8&qid=1464195379&sr=8-2&keywords=battery+tender+trolling+motor
Beefy? Yes
Strong? yes
Pricey? Kinda
Wonderful? Absolutely!
Shopped around for a while for one myself. Wasn't a fan of the other plug style QDs. This one is the best option on the market IMO.
